Im using Rapid Cart Pro
Its really great.
I’m using the RCP Grid stack
I can’t find if there is a way to loose that word VERSIONS above the add to cart button. I am selling one off paintings so there are no additional versions
I have the same “problem”. My fix is to remove the word “Versions” from the product part of Customization/Localization. If you update RCP, the word needs again to be removed.
Would be nice if this would be optional.
oh Thank you jochenabitz
Fantastic
As suggested by @jochenabitz, removing translation of Versions is the only way to hide the word from default product page, but you shouldn’t need to remove it every time you update RCP. Could you confirm, @jochenabitz?
Anyway, I suggest to use RapidCart Pro Stacks if you want to fully customize a product page.
Here’s an example.
http://rcpro.4gnd.com/demo/official/stacks/
Hi rob,
i have to remove it after updating RCP. I think all fields which are removed are filled with standard text after updating. But i have to watch this better next time, because i am relative new to RCP.
So just use a space.
I am sure this will work.
Yes I have never had to re do it and I update RCP many times a day
