Clearsite1
(James Martland)
1
Just rebuilt a site in RW.
Ball top menu links have died.
Using stacks + Foundation
Tried Joe Workman Top Nav stack and then other menu stacks - same result:- all looks OK but links are inactive.
The linked pages exist:
for example http://www.bonviveurjersey.com/contact/
But are inaccessible obviously.
Also tried creating a menu manually with manually added links. Again same result - links are non-existent. (Maybe a clue there?)
Odd!
tav
(Andrew Tavernor)
2
This will sort it out if you put it in site wide CSS.
.impact-wrapper>.pre-loader.hidden{
visibility:hidden!important;
I have filed a bug report on this matter so I am sure it will be sorted in an upcoming update so that you won’t need the CSS.
Clearsite1
(James Martland)
3
Brilliant - many thanks. Was driving me nuts…
