Hi All
Does anyone know how to delete add ons/plugins manually. I am getting error messages when opening about ‘Principal Class’ and ‘Metamate’
I can not see them in the usual manage add ons manner.
Any ideas.
Thanks in advance!
Hi All
Any ideas.
Thanks in advance!
Open RapidWeaver. Then hold down command+option and push 7. This will open the RW Addons folder in the finder. Then find the items you wish to delete and remove them.
You are probably using new version of RW and the the problematic add-ons are installed in a location used by older version of RW. This has been discussed many times. Drop something like “add-on locations” into the Search area of this forum…
