Hello. Is there a quick way of deleting all themes in my Themes library, except for one particular designer?
If you are talking about themes that are built in you can’t… If you are talking about themes you installed you just right click on the theme. The popup menu gives you the option to show contents of the theme. From there you can delete the theme you want to get rid of.
Hi, you can remove the built in themes, I delete the old themes I will never use by right clicking the rapidweaver app and going to show package ( I think… not in front of my mac) then to resource folder and look for themes folder and remove the themes you want. Only issue is that when you update the app you have to do the above steps again.
