Proper Method For Uninstalling RapidWeaver, Themes and Stacks
Hello Community… I have been doing a considerable amount of testing with RapidWeaver, Stacks and a few Themes. Now I would like to uninstall everything and do a fresh install of only the RW Application, Themes and Stacks I have decided upon.
What is the proper method for doing a total uninstall of RapidWeaver, Themes and Stacks?
Kind Regards,
Dave
Hello Again… Would truly value input from RapidWeaver or someone who knows how to do this. I need to do a fresh install of all newly purchased RapidWeaver, Stacks and Themes and want to be sure I am starting fresh.
Kind Regards,
Dave
If you want to remove RapidWeaver, and all addons, you can:
  1. Move the RapidWeaver.app file to the Trash.
  2. Locate the ~/Library/Containers/com.realmacsoftware.rapidweaver6 folder and move that to the Trash.
  3. If you do #2, you must immediately restart your Mac.
  4. Seriously: you must restart your Mac - the Container folder is managed by the system and you will be unable to re-enter your serial numbers when you reinstall RapidWeaver.
  5. Have you restarted your Mac? If so, good. Now’s the time to download RapidWeaver: http://realmacsoftware.com/rapidweaver/#releasenotes
  6. Assuming you’ve restarted your Mac in #3, launch RW and start afresh.
Note: I know I’ve repeated myself a few times about the restarting of your Mac when removing the RapidWeaver container folder. But you absolutely must in order for OS X to recreate that location when you relaunch a fresh download of RapidWeaver.
—Nik
Many Thanks… I will give this a go. Also thanks for emphasizing the restart step, something I usually do anyway but do appreciate you pointing that out.
Kind Regards,
Dave
On a similar note, I have a question to @nikf.
What do I need to do and where to look, if I want to get rid of all the remnants of older versions of RW and files left behind it in the OS? By older versions I mean pre-RW6.
RapidWeaver 5 and earlier all use the same location for addons.
~/Library/Application Support/RapidWeaver
—Nik
@nikf – So, in other words, I can safely delete the RapidWeaver folder from that location?
Correct, if you’re planning on not ever using RapidWeaver 5 or earlier :slight_smile:
Thank you, @nikf. I will do that…
