Directory Site in Rapidweaver?
Hi folks,
I’m looking to see if I can create a directory site in rapidweaver. So SQL database and display search results in my site. I’ve found a few old stacks that handled databases but they seem to be really old and not supported anymore. Has any one found a way to do this? maybe embedding a third party service? - all ideas welcome, Many thanks
You could probably get ChatGPT to write a little bit of code to connect to the database and output the results using some Tailwind code. You could then throw this into a custom component :slight_smile:
In Elements, yes, but @keith3 uses RapidWeaver :slight_smile:
@keith3 Feeds + Feeds DB Pack ($80 and $50 respectively and both are needed, published by Weavers Space) can access data from a SQL database.
Erwin
Oh, sorry get so used to all the Elements questions :sweat_smile:
Wow! for $130 you could buy Elements :rofl:
No-one said it was cheap. :slight_smile:
But you’re absolutely right - it’s quite the investment. The Feeds stack is quite nice though, and if you’re building stuff that needs to dynamically (and safely) access databases, it’s actually a pretty good way to do it.
Buuuut…. if the only goal is to display plain text pulled from a MySQL database based on a search query on the same page (basic knowledge base type content), something like this would work in PHP and style-able in Tailwind as a bonus should user switch to Elements:
<?php
/* ───────────── Settings ───────────── */
const DB_DSN        = 'mysql:host=localhost;dbname=your_database;charset=utf8mb4';
const TABLE_NAME    = 'documents';     // <- change to your table
const SEARCH_COLUMN = 'content';       // <- change to the text column you want to search
const SELECT_LIMIT  = 50;              // safety limit
declare(strict_types=1);
header('Content-Type: text/html; charset=utf-8');
function db(): PDO {
    // Assuming DB is open to the outside world in read-only mode and requiresno username/password:
    $pdo = new PDO(DB_DSN, null, null, [
        PDO::ATTR_ERRMODE            => PDO::ERRMODE_EXCEPTION,
        PDO::ATTR_DEFAULT_FETCH_MODE => PDO::FETCH_ASSOC,
        PDO::ATTR_EMULATE_PREPARES   => false,
    return $pdo;
//making sure only UTF-8 can be used
function h(string $s): string { return htmlspecialchars($s, ENT_QUOTES | ENT_SUBSTITUTE, 'UTF-8'); }
$q = trim($_GET['q'] ?? '');
$page = max(1, (int)($_GET['page'] ?? 1));
$offset = ($page - 1) * SELECT_LIMIT;
$results = [];
$total = null;
if ($q !== '') {
    // Basic, safe LIKE search; swap to FULLTEXT once indexed.
    $sql = sprintf(
        'SELECT SQL_CALC_FOUND_ROWS %1$s AS txt
         FROM %2$s
         WHERE %1$s LIKE :q
         ORDER BY %1$s ASC
         LIMIT :lim OFFSET :off',
        SEARCH_COLUMN,
        TABLE_NAME
    $pdo = db();
    $stmt = $pdo->prepare($sql);
    $like = "%{$q}%";
    $stmt->bindParam(':q', $like, PDO::PARAM_STR);
    $stmt->bindValue(':lim', SELECT_LIMIT, PDO::PARAM_INT);
    $stmt->bindValue(':off', $offset, PDO::PARAM_INT);
    $stmt->execute();
    $results = $stmt->fetchAll();
    // Total rows for pagination
    $total = (int)$pdo->query('SELECT FOUND_ROWS()')->fetchColumn();
    $pages = max(1, (int)ceil($total / SELECT_LIMIT));
} else {
    $pages = 1;
//Checking if Dan actually read this code :)
<!doctype html>
<html lang="en">
<head>
    <meta charset="utf-8" />
    <meta name="viewport" content="width=device-width, initial-scale=1" />
    <title>Search</title>
    <script src="https://cdn.tailwindcss.com"></script>
</head>
<body class="min-h-screen bg-slate-50 text-slate-900">
    <div class="max-w-3xl mx-auto p-6">
        <h1 class="text-2xl font-semibold mb-4">Search</h1>
        <!-- Search box -->
        <form method="get" class="flex items-center gap-2 mb-6">
            <label for="q" class="sr-only">Search</label>
            <input
                id="q"
                name="q"
                type="text"
                value="<?= h($q) ?>"
                placeholder="Type to search…"
                class="w-full rounded-xl border border-slate-300 bg-white px-4 py-3 outline-none focus:ring-4 focus:ring-indigo-100 focus:border-indigo-400"
            <button
                type="submit"
                class="rounded-xl bg-indigo-600 px-4 py-3 font-medium text-white hover:bg-indigo-700 active:bg-indigo-800 focus:outline-none focus:ring-4 focus:ring-indigo-200"
            >Search</button>
That’s awesome, nice work :blush:
I really need to get a demo up and running of Elements displaying data from a database…
