I use DISQUS on several pages on my website. At the DISQUS comment area, Disqus ‘kindly’ adds also other saved comments, which is fine and looks very helpful. However, these links redirect to non-existing url’s.
Is there nobody that has a clue, hint, suggestion? Is it a java script? Or is it that Disqus gets confused as i have several post on seperate pages and so not only on the Post(er) page?
It looks like an issue with Disqus. If you click on the actual comment link (i.e.‘1 comment’) it opens fine. If you click on the header (i.e.‘Harvesting rainwater’) then it doesn’t. Is odd though because when you hover over the header link you can see that it is the correct url but when you click it the “/” disappears from between “net” and “posts”. If you manually add that in then the page opens fine
I think I have found the solution within the DisQus admin: Need to migrate old url to the new ones, as I migrated from http:// to https:// lately. Will keep you posted and/or close this topic if I hopefully have solved it.
