does anyone have a solution to the colour band at the bottom of the hovered stack. Simply put when you hover over the stack the image zooms slightly and the hover title appears. But at the bottom also appears a band of colour which happens to be the same colour as the subtext colour. Even on the dkstacks site this happens here: http://www.dkstacks.com/stacks/hovermate/
It’s only when using the Daniel Effect in Safari anyway so that would be a developer issue not centering the image or adding padding to the bottom of the image when zoomed out… which shows the color you mention
Contact the dev with a bug report
would be my suggestion.
Brad
