Does RW 6 work on Mac OS Sierra?
Quick question to the RW community…
Has anyone that still uses RW 6.4 upgraded to Mac OS Sierra yet? I am stuck with RW 6 until it is safe to use RW 7 with my PHP-heavy site and I don’t want to risk any incompatibility with Mac OS. So has anyone out there upgraded to Mac OS Sierra and successfully kept using RW 6?
Any comments appreciated.
No reports of any issues so far here.
any news? Is it safe to upgrade to Sierra?
I’ve still not heard from anyone about their success with RW 6.4 and MacOS Sierra, so I’ve continued to hold off upgrading.
So am I… maybe I could find out with my other computer. I’ll try it end of next week, after the 20ies of November. Then I’ll inform You.
I regularly test Stacks 3 + RapidWeaver 7 on:
Mac OS X 10.11 El Capitan and macOS 10.12 Sierra
And Stacks 3 + RapidWeaver 6 on:
10.9 -> 10.12
There are some slight cosmetic differences and a few tiny behavioral ones – but mostly things work well across the board.
I work with RW 5, RW 6 and RW 7 on Mac OS Sierra. So fare no problems.
Thanks @isaiah and @Kunstmaler - I appreciate the information. I’ll go ahead and upgrade this weekend then.
Thanks @isaiah and @Kunstmaler for the information. Any news on RapidBlog working in the Sierra configuration? For me is the most critical issue for the time being.
I only use RapidBlog once. With RW 5 ! This website was updated 2 weeks ago and found no problems.
I am not aware of any plugins problems with Sierra (we try to take care of those sorts of things well before the release date). :slight_smile:
I’ve now been using RW 6.4 on Sierra for 2 weeks and I’ve not had any problems at all.
Great! thank You for Your answer. I will then dare to move on to Sierra soon…
