Duplicated upload resources
I hope to explain my problem: I have over 100 files mp3 to publish in my RW site. All the times I try to publish the site, RW tries to republish all the resources files and at the very end (128 files / 132 files or similar) it gives a timeout server error, so when I click “publish”, it restart from the beginning.
The resources files have always the blue dot.
How can I do?
I had the same problem. What solved it for me was to make a folder on my server with my FTP program and I uploaded the movie there, then just link to that folder. Looks like you can only add very small things to the resources folder… Just don’t name the folder resources, name it my-music or something like that. Instantly solved same issue as you Hope that helps you. Aloha
