Hi all,
Just started using easy CMS
The admin selection of stacks has a select stack
I can figure out what the use purpose of this would be? Is there any documentation on this as I can’t see how the select can trigger anything?
Hi all,
allow your user to select pre-determined text that you define.
Thanks for the reply!
Where does this text end up? Does it input into a text area?
You use it exactly as you would a regular text field.
