I’m using the Sweep theme from One Little Designer. Here is what happened …
Has anyone had this happen? How do I fix it??
Hi, @trinafreeman
looks like you made partial from your page.
Click that ‘Unpack’ button between Library and Hiden buttons.
Other options are:
Undo last moves
Cmd+z to undo
The emergency trick to use with caution
If you didn’t save your project file yet, just close your project without saving, and reopen it. You might lose some of your work depending on when you saved last time.
