Elements 0.6 (23271)
Hello again,
This is the first Early Access build of Elements for macOS :tada:
Make sure you have your volume turned up when you first launch it :wink:
What’s New in Elements v0.6 (23271)?
  • Refined Welcome Screen for Early Access builds
  • New Debug Panel added (useful when building Dev Components)
  • Pressing return in the Quick Add window now inserts the selected component into the page
  • Quick Add search now ignores case
  • Added Globals and Custom Components to Quick Add Window
  • Accordions can now be opened or closed on page load
  • Tags now support different match modes (Single, Multiple, All and Any)
  • Fixed Backgrounds and Gradients not working in Text Component
  • Divider is now listed in the Component area
  • Fixed an issue with the Base license and Global limits
  • Switched to a new version numbering scheme for Early Access builds
Download Elements
You can always download the latest build of Elements using this link.
Purchase a License
Get the Update
Give Feedback
Request a Feature
You can help make Elements even better by sharing your suggestions and voting on others.
Please remember to search before posting as it may have already been suggested. If your idea is already listed, you might want to upvote it. The more votes an idea gets the sooner it’ll get implemented.
It would be nice to have an option to have the sound play or not on startup. :wink:
Only plays once! No option needed. Hoped you liked it!
@dan, What I meant is Yes I did like it and I would like to have the option for it to play every time or on demand when giving demos etc.
I only got to hear half of it as the speaker didn’t kick in until about halfway through.
Opening was awesome!! Loved it!!
