Elements Base Branding?
Dan, can you show us what the embedded Elements branding will look like for those who purchase Elements Base?
Hey @bruce we haven’t designed it yet, but I should think it’ll be a subtle floating badge (or similar). We’re open to suggestions here.
You can always upgrade to the Plus version once Elements goes live.
Hope that helps!
@Dan, Thanks for the info. My web creation needs are minimal these days since I retired 7 years ago. I still have one site where I sell depression glass. I’m still using RW8, and it’s working fine for my needs. I will upgrade to Elements when it is released. Elements Base is all I need. I’ll be fine with your branding as long as it is not a distraction.
My suggestion is a user-customizable ‘Made with Elements’ button they can place anywhere in the footer. It may or may not link to the Elements website, that choice should be left to the user.
Thanks for the feedback, we’ll take this on board!
FYI: It’s only the base version that has branding. The Plus and Pro license remove all branding.
Yes they do! :slight_smile:
@dan Can you show us now what the branding looks like?
We’ve not implimented it yet, but it will look similar to RapidWeaver Classic’s badge feature. Like this…
Thanks.
