Elements Beta 10 (Build 22887)
Hello again,
Just a quick update following on from yesterday’s release of Beta 9 and Elements Cloud to help those of you trying to log in with Gmail.
What’s New in Beta 10?
  • Added ability to sign-in using a code
  • Improved handling of cloud documents
  • Improved error reporting during document download
Update to the latest Beta
Elements should prompt you while it’s running to let you know there’s an update, if it doesn’t you can select the “Check for Updates…” menu option from the “Elements” app menu. You can also download the latest build of Elements from the confirmation email you received as that link will ALWAYS give you the latest version.
Give Feedback on the Beta
If you are using the beta, please post all feedback in the Elements Beta Feedback Forum . You can use the Elements > Send Feedback… menu item to automatically pre-fill the build number into a new topic.
Get the Beta
If you’ve already signed-up for the beta, it might be a while before you get an email as we’re working our way through all the feedback. Hang tight for a little longer, you will get access in the coming weeks and months.
If you’re not on the list, you should sign-up up here to be notified when the beta is publicly available.
Dan & Team Realmac
I tried everything to become a beta tester for eelements. No way to get even my in to ask the question to become a beta tester. I am so sorry that all these people got in without my understanding how they did. Bought th classics version especially to get in the test program, but … no chence. Who can help me?
Check your email :wink:
