Elements Beta 26 (build 23158)
Hello again!
As these builds are coming thick-and-fast, perhaps we should switch from calling them weekly beta builds to nightly builds?!
Anyway, here’s another great release, hot off the production line:
What’s new in Beta 26?
  • Creating anchor links in the Typography Component now work!
  • Fixed an issue with projects crashing on open
  • Fixed editor crashing if component content is invalid
  • Numerous other under the hood stability improvements
Get the Update
Please note: Sometimes it takes a while for the update to propagate. If you don’t see the update in-app, you can download the latest build of Elements from the confirmation email you received, as that link will ALWAYS give you the latest version.
Give Feedback
Can I join the Beta?
We’re not taking on any more beta testers at this time; however, you should sign up here to be notified as more places become available.
