Elements Beta 20 (build 23031)
A new week, deserves a new Beta, so here’s beta 20 — It’s a goodie, enjoy!
What’s New in Beta 20?
  • Components can now be dragged into Flex and Grid Components
  • HTML is now escaped correctly in Text Components (use a Custom Component if you need HTML)
  • Added new V2 Gallery Component (still a work-in-progress)
  • Text: Fixed issue with setting link styles
  • Button: Added dropzone support (perfect for adding SVGs)
  • Standard Navigation: Added margin support for logo
  • Fixed an issue where the node tree would sometimes cause crashes editing the page
  • Improved Document saving so it doesn’t crash or display a warning telling the user an external application has modified the document!
Get the Update
Elements should prompt you while it’s running to let you know there’s an update, if it doesn’t you can select the “Check for Updates…” menu option from the “Elements” app menu.
Please note: Sometimes it takes a while for the update to propagate. if you don’t see the update in-app, you can download the latest build of Elements from the confirmation email you received as that link will ALWAYS give you the latest version.
Give Feedback
Can I join the Beta?
We’re not taking on any more beta testers at this time, however you should sign-up up here to be notified as more places become available.
Title wrong…
:person_facepalming: Fixed!
I have run into a different problem with saving a project. I went to close a project and a dialog showed up saying the application was saving and did I want to wait. I said I would wait and then I could no longer QUIT the app and had to force quit. Not sure if I did something to trigger this, but all I had done was look at the new support for icons in a button.
Can you create a demo project incorporating all the major features included in beta 20?
