Elements Beta 3 (Build 22822)
Thanks for all the feedback since Thursday, we’ve been blown away with how kind and constructive it’s all been — Seems a lot of you agree, we’re on to something special with Elements :smiling_face:
Every single fix in this build is a direct result of the feedback you’ve posted on the forum, so thank you and keep it coming!
Anyway, with that out of the way, here’s the release notes for today’s beta update - it’s a biggie!
What’s Fixed in Build 22822
  • Globals no longer mysteriously disappear from the sidebar.
  • Features, Footer, and FAQ Sections now work with Data!
  • Added Tooltips for Toolbar and Sidebar.
  • Allow new Folders to be created when right-clicking on resources.
  • Increased the font size in the Notes area for the old-timers amongst us.
  • Dragging a resource over the editor no longer inserts images for future drags.
  • Before Closing Tag editor now visible in the Body code tab of Project Settings.
  • Menu Component: Links now work!
  • Button Component: Links now work!
  • Menu Component: Added flexible resizing to logo.
  • SVG Component: Improved compatibility and output.
Start Your Update Engines
Elements should prompt you while it’s running to let you know there’s an update, if it doesn’t you can select the “Check for Updates…” menu option from the “Elements” app menu.
You can also download the app again from the confirmation email you received as that link will ALWAYS give you the latest version.
Dev Diary Tuesday
I’ll be going over some of these changes in the Dev dairy diary tomorrow, and sharing a fun little project with you too, here’s a sneak peek.
See you tomorrow!
Dan & Tea, Realmac
hmm “Dev Dairy” LOL
Mmmmmm dairy…
drooling-homer-simpson
