Hello again,
Today’s beta is another big one! It has a tonne of fixes and enhancements, but most notably, it now has native Anchor support. Watch Dev Diary 50 to learn more about Anchors.
What’s New in Beta 22?
- Added Anchor Support to Link Panel
- Added ID(Anchor) support to all Components!
- Remove keyboard shortcut for old preview view
- Add duplicate to custom components
- Creating a link to a resource in Typography or Text now works.
- Fixed extraneous
bradded in Text editor. - Themes now support Typography Defaults (we just need to set them up…)
- API: Added absoluteURL option to link controls
- API: Added Anchor support (rw.AddAnchor)
- Added Smooth Scroll class to default site Template
- Flex: Added link option
- Grid: Added link option
- Further improvements to text output
- Linking to resources now working in text areas
- Gallery: Further improvements, including Lightbox styling options
- Container: Gradient Hover now works on background
- Container: Gradient Transparency now works
- Background overlay opacity now works in Dark Mode
- Improved copy/paste and undo for custom components
- Quotes are now handled correctly in custom component titles
- Various other minor fixes and improvements.
Get the Update
Elements should prompt you while it’s running to let you know there’s an update, if it doesn’t you can select the “Check for Updates…” menu option from the “Elements” app menu.
Please note: Sometimes it takes a while for the update to propagate. if you don’t see the update in-app, you can download the latest build of Elements from the confirmation email you received as that link will ALWAYS give you the latest version.
Give Feedback
Can I join the Beta?
We’re not taking on any more beta testers at this time, however you should sign-up up here to be notified as more places become available.
