Elements Beta 24 (build 23142)
Hello again,
Today we’ve released Beta 24, this one features the new Reveal Component, watch this weeks dev diary if you want to learn more about what it can do!
We’ve also fixed a whole bunch of bugs and instabilities — Especially relating to the editor and the resources area. As with each new beta, we can safely say, this is definitely the best version of Elements yet :laughing:
Enjoy!
What’s New in Beta 24?
  • Added new Reveal component
  • Faster Document Loading (very noticeable on larger projects and slower machines)
  • Fixed issue with the scroll position resetting when changing anything in resources, page or project settings
  • Fixed Resource issue with thumbnails not loading and hanging/crashing the app
  • Fixed issue with Editor not updating when first opening a document!
  • Double clicking anywhere in a text component will now enter edit mode
  • Text Component now supports Borders
  • Button Component now supports different case styles
  • Fixed Property order for flex and grid
  • Fixed an issue with Text opacity colours
  • Add regex support to the expression parser for property hidden/visibility states in the Elements language
  • Fixed a crash when inserting new items while a filter is active in Page and Resources
  • Do not allow page deletion if there is only one page!
  • Fix editor initialization unnecessarily running multiple times
  • Under-the-hood memory management improvements for tree based views and more
Get the Update
Please note: Sometimes it takes a while for the update to propagate. If you don’t see the update in-app, you can download the latest build of Elements from the confirmation email you received, as that link will ALWAYS give you the latest version.
Give Feedback
Can I join the Beta?
We’re not taking on any more beta testers at this time; however, you should sign up here to be notified as more places become available.
fyi the beta 24 is not showing up yet.
@LaPan see above, and below, it sometimes takes a while to propagate!
@dan With this BETA 24 it seems to have broken something in the BUTTON component. When there is a drop zone present in the button the title is pushed to the left and the drop zone to the right.
Was working perfectly before this BETA.
If you set the button to have NONE for the drop zone the title stays pinned to the left. From what I can tell the title seems to be ignoring the justification text settings. Adding the drop zone to the left will cause both to be left aligned regardless of the justification setting.
UPDATE: this is still working perfectly in the browser, so there is something in the editor that is not working correctly. Buttons that were in a global do not seem to be affected, title alignment is correct.
Dan, there may be a glitch with the Beta 24 update.
@dan
Virtually all of the bugs I have reported have been squashed. It is looking good. Resources issues I was having, so far appear to have been fixed.
One issue that has not been fixed: Shift clicking in the text component still is broken. When you shift-click to select a measured amount of text, the editor will exit editing mode and just select the component itself. You can drag and select text as a work around.
Elements is looking good and is headed towards a solid release!!
@dan
Setting an inline link to an anchor in a text block is still not working.
Adding REMOTE SVG files still appears to be broken in Resources. Shows up with a warning sign in front of the file name, after adding.
Can you share a small project showcasing the issue? We’ll look into it and get this fixed asap.
Can you also share a sample project with these issue in also - it really helps speed up the fixes :raised_hands:
Aloha Dan,
Both examples are in this small project. Although in here the button is behaving differently than in my working project, but it is still not correct. There are also two resources, one remote and one local.
There are two buttons. The blue one I created from scratch and the red one I dragged in from my project. Both buttons display correctly in the browser but not in the editor. If you change the text alignment nothing happens to the text in the button. But it does the right thing in the browser.
elementsapp://downloadDocument/VqQVCYMCqn13
I also added an example of a link to an anchor inside a typography component. It does not work in this component, but a link to an anchor does work in a TEXT component. Sorry I had tested this in this project with a TEXT component, not remembering the problem was in a TYPOGRAPHY component.
Hi Dan,
I am having the same issue with buttons, the text is on the left within elements.
Yet displays fine in preview.
me too
Sorry about that, we’re just working on a fix now… look out for another beta later today!
Thanks for the sample document, it was super helpful! The Button text issue is fixed in Beta 25 (available now-ish), and the other issues should be fixed in Beta 26 due later this week :crossed_fingers:
I can confirm that all is good now with the buttons. Mahalo!
