Elements Beta 31 (Build 23180)
Hello again,
Hot on the heals of beta 30, predictably we have beta 31. This build contains some Workspace fixes (although we still have more to do). It also contains ALL of the Component fixes that should have been in beta 30, plus a bunch more!
What’s New in Elements Beta 31 (Build 23180)?
  • Switching Workspaces no longer breaks Editor resizing
  • Components no longer get duplicated when dragging from Editor into the Node Browser
Component Updates
  • Video: Improved MP4 support
  • Video: Added custom placeholder support
  • Container: Fixed issues when hover effect is set to self
  • Button: Shadow hover is not set to none by default (as it should be!)
  • Image Component now supports Dark & Light Mode images
  • Image: Updated Image resizing options
  • Reworked Video Component
  • Translate Horizontal now has a default value on all Components
  • Reveal: Added full sizing options including breakpoints
  • Container: Background images are no longer resized
  • Container: Switching a background image no longer shows an error
  • Text: Fixed Text underline styling issue in Edit mode
  • Removed Collapse from Visibility options as it’s only applicable to Tables
  • Menu: Now supports three levels of nesting
  • Menu: Fixed issue with sub items in mobile menu being repeated
  • Menu: Fixed issue with sub menu items showing when they should be hidden
  • Menu: Drop down menu arrow now matches text colour on mobile menu
  • Menu: Added Sub menu bg color and blur options
  • Menu: Added an options to independently set the background colour of the drop menu
Join the Private Beta
Post a comment below requesting access and we’ll send you the details via the email address attached to your forum account.
Get the Update
Please note: Sometimes it takes a while for the update to propagate. If you don’t see the update in-app, you can download the latest build of Elements from the confirmation email you received, as that link will ALWAYS give you the latest version.
Give Feedback
Request a Feature
You can help make Elements even better by sharing your suggestions and voting on others.
Please remember to search before posting as it may have already been suggested. If your idea is already listed, you might want to upvote it. The more votes an idea gets the sooner it’ll get implemented.
was this the intention for video, a couple of tries I had YouTube playing in the browser rather my video, unable to replicate. if no controls plan until you click
That looks like a bug, we’ll get it fixed :saluting_face:
This new BETA has a problem with borders on a text component as far as I can tell. I have a header in my footer that has a border on the left edge. For some reason now it is drawing THREE borders on the edge.
UPDATE: This problem is limited to the editor display and is not reflected in the browser.
@dan Something has also happened to margins. All of the places where I have a HEADER that had the top and bottom margins originally set to 2 are now displaying with much larger margins. So either the margins were not working properly before or something else has changed.
This is how it looks now and below is how it used to look.
This is also causing problems with the typography component. I have my paragraphs setup to have some margin, which are now being displayed with much bigger margins.
As mentioned before I’m not sure if this is because they were not working correctly in the previous BETA or this one broke them. All of this was fine in BETA 30.
Thoughts.
UPDATE: these problems are not reflected in the browser, they appear to be problems with the display in the editor.
Hmm, that’s not right! Can you share your project so we can take a look?
Aloha Dan,
Here is a project that has the problems, which are only visible in the editor.
elementsapp://downloadDocument/5CtIMVLYqxs7
Hopefully, I did the link to the project correctly.
I tried to add some of the other problems to this project, But I could not get copy and paste to work from one project to another. Which is incredibly frustrating. I am hoping we will have working Cut, Copy, and Paste in the not too distant future. It is very frustrating that this does not just work.
I have also noticed the Mac spinning beachball more often in this build…way more in fact
This is a bug in edit mode and will be fixed in the next beta!
odd no text color
Tried reproducing it here and had no luck. Can you share the project so we can take a look?
reopened Elements and dropped in the text
elementsapp://downloadDocument/6ALpwRYbEaXa
You’ll need to set the colours for this text in the Theme Studio under Typography. We haven’t got around to adding any defaults yet, but when we do, this will just work.
Keen to get experience with Elements beta so I can get some hands-on learning experience before it is released. I have used RW since v5, but really struggled with the whole Stacks and Foundry stuff (no offence intended - this says more about my lack of skills), but can already see that Elements will make it much easier for me to develop the websites I envisage.
That’s great to hear — I have sent you the beta details via email.
this was working , the text was black I think, just opened other pages I produced previously the text no longer shows unless I change colour
