Elements Beta 2 (Build 22806)
Lots of great updates in this new build, but @anon68150607 and @scottsteven had trouble using the built-in updater so we’re looking into it now, but we are wondering… @Bruno @upssjw did you guys hit this issue or has it updated just fine?
If you’re not on the beta yet, don’t panic, you can request access here.
What’s New
  • Previewing your projects in Safari (or any browser for that matter) Is now supported.
  • Exporting and publishing sites now works!
  • Custom fonts now work!!
  • Resource images and folders can now be dropped into the editor (more resource types will be supported soon).
  • Replace images on your page by dragging resource images directly onto them.
  • You can now drag resource images onto an Image Component.
  • Woff2 icons a nicer icon.
  • The “Desktop Dropzone” has been renamed to ensure the name is fully visible and not truncated.
Uh, I’m struggling a little with Timemachine. I’ll get back to you as soon as possible.
ADD : Update ok. Gallery still doesn’t work. Navigation Menu doesn’t work and a problem appears : when we select it, it freeze.
Updated fine, checked preview in safari works, just got in so will check rest out in an hour
publishes to my external drive now, excellent
