Elements Beta 30 (Build 23176)
Hello again,
As promised, here’s a fresh beta with the new Workspace Manager included. There’s also a whole heap of other component fixes, including Dark and Light mode image support — Have fun!
Known Workspace Issues
  • Controls look disabled in windows (but they still work)
  • Editor sometimes fails to resize correctly (restart app to fix)
What’s New in Elements Beta 30 (Build 23176)?
  • New Configurable user interface
  • New Save and Manage Workspace layouts
  • Image Component now supports Dark & Light Mode images
  • Image: Updated Image resizing options
  • Added support for pageStart/pageEnd areas in shared components
  • Added support for PHP files in component and shared templates
  • Reworked Video Component
  • Translate Horizontal now has a default value on all Components
  • Reveal: Added full sizing options including breakpoints
  • Container: Background images are no longer resized
  • Container: Switching a background image no longer shows an error.
  • Text: Fixed Text underline styling issue in Edit mode
  • Removed Collapse from Visibility options as it’s only applicable to Tables.
  • Menu: Now supports three levels of nesting
  • Menu: Fixed issue with sub items in mobile menu being repeated
  • Menu: Fixed issue with sub menu items showing when they should be hidden
  • Menu: Drop down menu arrow now matches text colour on mobile menu
  • Menu: Added Sub menu bg color and blur options
  • Menu: Added an options to independently set the background colour of the drop menu
Get the Update
Please note: Sometimes it takes a while for the update to propagate. If you don’t see the update in-app, you can download the latest build of Elements from the confirmation email you received, as that link will ALWAYS give you the latest version.
Give Feedback
Request a Feature
You can help make Elements even better by sharing your suggestions and voting on others.
Please remember to search before posting as it may have already been suggested. If your idea is already listed, you might want to upvote it. The more votes an idea gets the sooner it’ll get implemented.
Can I join the Beta?
We’re not taking on any more beta testers at this time; however, you should sign up here to be notified as more places become available.
Nice work on the workspaces. Now, under Manage Workspaces we need renaming, plus I’d like to see Save as Default on This Machine. Why that latter bit? Because of moving between laptop and desktop. Be nice if Elements knew which machine I was working on and changed my workspace accordingly.
Hi @dan : another incredible update !!
I found this bug: When the inspector is moved to the bottom of the screen, the segments no longer expand. When you then choose the default settings, the inspector is returned to its original position, but the segments still cannot be expanded.
Similar issues here when I try to rearrange the user interface. Can’t expand them anymore. And I can’t even manually resize the canvas after changing the UI. Restarting Elements helps though.
@dan : another bug.
When the bottom section is resized, it doesn’t move gradually. When you try to enlarge it to see more code, the panel jumps all the way to the top of the screen. It’s not possible to reduce the section size by dragging the slider downwards.
Update: I discovered the show/hide inspector in the top and that works fine.
was this supposed to be removed or am I reading this wrong
Hmmm.When I select Check for updates…, I see this error message.
OK, tried again and the update works.
Thanks @Bartje, we can reproduce the issue here and will get it fixed. In the meantime, if you switch pages, the inspector should start to work again :+1:
Component updates accidentally didn’t get included in Beta 30, they will be in Beta 31 due out this evening!
Thanks for the report, we’ll get this all fixed up!
Beta 31 (due this evening) should fix the canvas resize issue, in the meantime you can just switch pages and the inspector will start working again.
For now, you can use the Save As… function and delete the older one. Not ideal, but it works!
