Embed Twitter Feed/Timeline in RW Site?
Howdy Weavers- I’ve banged my head against a wall and give up. Maybe you can help…
This should be simple: How do I embed my twitter feed into my RW site? I don’t think there are stacks since it’s just a twitter widget, but when I following these instructions: https://support.twitter.com/articles/20170071
I don’t have ‘timeline’ as a widget option. Anyone done this a different way or have has a similar problem? Any guidance?
Thanks!
I’ve used this link recently and it worked fine for me:
https://publish.twitter.com/#
Just put in the users twitter url, select your customizations, and then put it into an html stack (make sure to paste as plain text and/or use the ‘ignore formatting’ option in RW).
http://demo.yuzoolthemes.com/wall/ By @yuzool
Thanks for the help. That was incredibly easy. Not sure why official guide gave other instructions, but oh well. I went ahead and installed the code, but had to add a data-tweet-limit=“2” or the tweets went on forever.
Thanks for the help!
