Hello
If I embed a SoundCloud playlist (with tracks from my profile) on my website and I add tracks on that playlist on Soundcloud itself later on, will the embedded playlist on my website also be updated or do I have to redo that part of my website?
teefers
(Doug Bennett)
25 July 2021 20:21
2
I don’t have SoundCloud, but I understand that the embedded item is a iFrame?
If that is the case then it should get that playlist “live” from whatever the latest is on SoundCloud.
Should be pretty easy to test, just add it to the webpage, change the playlist on SoundCloud and see what happens.
I have a Soundcloud stack.
SoundCloud is pretty awesome. Its basically YouTube for audio. This stack allows you to easily embed songs, playlists and user streams directly onto your webpage. It works beautifully across all of your devices, even mobile.
I believe that Soundcloud also supports oEmbed, so this should work as well…
oEmbed allows you embed a widget from thousands of websites with a single URL. It uses the open oEmbed Standard to access any website that supports it. For example, you can easily embed the following widgets: Twitter posts, YouTube videos, and so...
system
(system)
Closed
26 August 2021 08:34
4
