When you click to the any pages, image’s banner collapse and it seems to be glitch or corrupt view…
just 2 seconds and then its ok but it is so strange… when loading a page its a caos.
Anybody have a suggestion to fix this issue please?
Take a look at this site http://www.mobila.it/
and click every page in the Nav Menù and u will see the “effect”…
I assume this is no glitch of the theme but just a matter of your banner images. I checked them out and noticed for them being way to big. By testing the website the problem you described did only appear on the first tome loading the website, but not on the second or third time as the images got cached.
I compressed them using tinypng.com and were able to save all in all about 3 MB.
Hi thank you so much for your excellent support but… yes i’ve compressed all the images with tinypng.com … and the result seems to be the same take a look please http://www.mobila.it/
Anyway thank you so much for your suggest… any other suggestions for me?! Please…
