I previously asked whether a stack could be written to generate epubs in Rapidweaver. I thought I’d update the question.
Turns out, generation of epubs is easy from the command line if you have the web page’s index file (index.html) in a folder:
Running the open source e-book convert utility from the command line yields the ebook:
$$>ebook-convert index.html book.epub
So making a Stack that would wrap the ebook-convert utility would generate the ebook from the web page.
I can’t imagine that this would require a great deal of coding.
Then perhaps the program could be run from within RW without a Stack?
The point is that all the hard work has already been accomplished by those who wrote the utility.
Their work does not need to be replicated.
I wear too many hats as it is; that’s why I posted on the forum.
Getting closer and closer…
Perhaps there’s some way that a script executed from within RW could call the command line and execute the epub creation file on the generated index.html project file.
Then RW would have epub creation functionality.
Here’s a website which can turn a website into an epub. Why couldn’t this functionality be incorporated into Rapidweaver? Giving Rapidweaver epub functionality would extend its capabilities and hence, its value. To those who said that his cannot be done:
