After publishing my site i obtain ‘403 Forbidden’ accessing my site url.
I’ve set 777 to index.html permission too …
I think permission on the index.html should be set to 644 – at least, that’s the case with my site…
First if the index file is where its supposed to be as per the instructions of your ISP i would suggest you call your ISP and have them check the web server settings.
I had a similar issue with a windows server for a client the ISP have screwed up IIS install index file in one folder and the subsequent files in another to get it to work . bloody nightmare.
Problem solved!
Many Thanks
@Roby962 – It would be beneficial for the rest of us if you explained how the problem was solved…
