An error message appears when I open the home page of a new site - I have tried changing the url in general settings from https://www. to just https:// but the error message persists. Obviously I am overlooking something here but i cannot figure out what.
Neil, Thank you for your prompt attention and suggestions regarding my post. As far as I can see I have entered identical urls in both General and Publishing settings. I have been known to overlook the most obvious - I will drop in two screenshots to illustrate this -
Neil, Well spotted! It’s my first ever attempt at using GoCMS, and the first time anything like this has happened so the two are probably related. I’ll check GoCMS settings.
The only setting necessary with GoCMS appears to be the the go-cms-key.php which is in resources. I can’t see anything in GoCMS which requires a url. I am using the latest version called GoCMS Unlimited.
Neil, I can still see it here on both Safari and Firefox. I’ll delete my cache and see if that makes a difference. Rather than keep you - if this doesn’t work I’ll set up the site without GoCMS and see what happens. Since this has never happened before, all things point to it being something to do with GoCMS. I’ll let you know if I solve it. Many thanks for your continuing attention.
Best wishes
Lang
Hello Philippe,
I haven’t yet found an answer to this problem - in my view it doesn’t send out a very trustworthy image of one’s website. Obviously something to do with goCMS.
Actually, I was just tagging Mike at Yabdab to take a look at this thread and the problem you and the other posters are experiencing. However I also have Go CMS Unlimited, so am interested in the issue and solution in case I experience the same situation.
