I’m envisioning a page with an array of pop box buttons that expose an answer to the FAQ [frequently asked question] proposed on the button.
swatch classifying them would enable color differential for inhanced page bling … any clever ideas or enhancement examples would be welcome.
hypertext links alone seem too limiting.
This is crude…take a look:
http://www.ibize.com/faq-sample/
thanks … that a beginning . clean and simple.
looking at “page source” html is intimidating.
is there a simple way to view structure in RW8 format?
i’'m lacking some of these stacks … i’ll check em out
are they stable?
paragraphpro , buttonpress2, Foundationgrummage2
I’m using RW8, Foundation 6, Stacks4 and cautiously use add-ons as crashing and loosing sunsaved work sucks.
That is a foundation1 theme…and stacks
just added a grid…very easy…the popup is expose @joeworkman
without stacks…it would be a nightmare!!!
If you can live with just an accordion…I updated the sample above.
Have a look at this post on Weaverspace, it is a FAQ solution built for TotalCMS but could probably be adapted, as it uses BigWhiteDuck’s PopDrop stacks. You could probably make it work.
https://community.weavers.space/content/perma?id=81999
This is the FAQ stack from doobox running in Foundation 6
Another option is an accordion stack. This is the Foundation 6 stack with the first item set to show on load but you can hide all the content or only allow one open at a time, change formatting etc.
Awesome! I had no idea a FAQ list could be so subtle but bountiful.
This is now my favor … sure wish i had a Foundation template as a starting point.
What stack is likely implemented
is it just an array of pop-drop , backgroundless buttons showing text only
Or you could use a FAQ stack that includes a search feature - useful if the FAQ grows over time.
There is also FAQ2 from Doobox
This is a WINNER
partly due to it’s modularity
