Hi all, i have, almost overnight, been unable to publish anything from RW, also i cannot access the Control Panel of the same Web Space, it is virtually the same for 3 web spaces that i have, each with a different host.
I did reset my Router but that didnt help, one of my Hosts suggested i use TERMINAL and TRACEROUTE which confirmed my problem.
Does anyone have a few more ideas Please, so that i can pin point the problem once and for all ?
@DaveFox thank you Dave that is an excellent suggestion, i am with PlusNet and the normal Phone Line , but i shall definitely check what my UpLoad speed is, thanks.
About average for your BB, if you do a lot of uploading you might want to look at BT Infinity. Broadband suppliers are like insurance companies - you don’t know who the bad ones are until you need them
