Flex Link option not showing
Hello,
I just updated to Elements Beta 22 and the link option is not showing in flex settings. I installed the update, restarted my mac, quit and relaunched Elements several times but still does not show.
Ah, sorry, those changes must have missed the Beta 22 Build. Doh!
Those changes will be in Beta 23 - Sorry for the delay!
No worries. I have also found a problem not being able to add an image into the drop zone for a button. When dragging the image over the button drop zone and releasing, the image either goes to the top or bottom outside the button. Things are looking very good! Thanks for providing us such a great improvement!
Instead of dragging an actual image try first dragging an SVG or Image component into the drop zone and then drag in the image into that component. I just tried this and it worked as expected.
Thanks Robin, I wasn’t thinking clearly. Works great!
