I have a page with quite a lot of text. Is it possible to have sections like on Wikipedia that you can ‘fold away’ on mobile. Or some links within the page to jump to a specific section like on Wikipedia Desktop? I have Stacks.
There are several “Read More” stacks, Try this one:
ParagraphPro from Big White Duck…you have to turn on child stacks.
It is free.
sample:pool cover | My Website
As @joemart1951 mentions, the “read more” approach is one way to do this. Another is to use accordion stacks: there are several around. One very good one is FAQ Toggle:
As for clicking on a link and being taken to the relevant location on a page. There are fewer solutions to this, but the most elegant one (in my experience) is the Jump stack:
Am I missing something that none of these can be used with a page consisting out of multiple stacks? I for example want to have Section 1, Section 2, Section 3. Each section will have text and a shutter stack for a photo gallery. None of these seem to allow having anything more than text.
Another option is to use Anchor and Link stacks. (Jump does this automatically, but Anchor and Link stacks take a more manual approach.) There are a few stacks that do this. Here are two:
https://www.doobox.co.uk/stacks_store/demos/anchor.html
and
Or another stack from ‘Stacks4Stacks’ - I think you can have other stacks inside the folding area
What specific Toggle stack are you using? I’d suggest contacting the developer. At a glance all I can say is you’ve set things up “incorrectly” but can’t offer any proactive advice.
If you are using ToggleFAQ stack by @habitualshaker then the screenshots below show how I’ve set up things and the result.
and
results in:
I use the stacks4stacks one Toggle | Stacks4Stacks
I found the error: I had another toggle without a text. So while it looked plain gray, it toggled a textfield.
Found out how padding works. It’s amazing how many things you can/have to change to get a specific look. I like this level of control. It costs a bit more time but I think it will pay of in the end.
