HI,
how do I create a page where you click on the text ¨read more¨and more text, pictures is opening up??
I´m using Strata, Voyager pro and Lunarthemes.
Lars
I think “Trunk8” might be the stack you’re looking for. It looks like a replacement for Bullet Pro that @SteveB mentioned.
You can also get 50% off at Doobox at the moment.
The S4S Toggle and TogglePlus stacks are both very good solutions.
There is also the ZipList stack, which is one of the original toggle effect stacks:
https://seydesign.com/stacks/ziplist/
Problem with trunk8 is it doesn’t support any formatting or html. Fine for just continuous text but that’s about it
I use Peek-A-Boo by @joeworkman for this functionality. Works well.
Thanks everyone for help. Trunk8 and Peek-A-Boo was perfect for my needs!
L
