Does anyone know how to solve these errors please?
Try linking to a jQuery CDN or hosting the src locally on your server.
Hello,
How is that done? j Query CDN, and hosting SRC? Can you provide a link please?
Is there someone from RapidCart Pro that can help please?
A link to your website please.
Thanks for the reply. The website is
can’t seem to change RCP colours to cart, layout stacks not aligning, and the errors in Safari Console/Debugger as above.
Hoping if the errors are fixed things will go back to normal
You have wrong code in I guess the side wide head code area:
<style type="text/css" media="all">})(jQuery);(document).ready(function($) {
$('#nav ul li').hover(
function() {
$('ul:first', this).show();
</style>
Then it seems the com_blueballdesign_freestacknavmenuT1_stack generates more JavaScript errors.
I would ask the BlueBallDesign developer for help.
Cheers, Jannis
inStacks Software
Thank you. I have emailed Blueballdesign, awaiting reply.
Will update here, when I know whats going on!
what’s not whats!!!
If someone from RapidCartPro is about please can you check to see if the 404Font Awesome error is due to the plugin?
It isn’t Freestacks/Stacks for that error.
First of all, please fix the jQuery problem. It should fix the Font Awesome 404 error.
There isn’t any jQuery problem on this page. It’s just font awesome 404.
Do you think it would help if I uninstalled RCP, and reinstalled, or something else?
Try republish all files.
Yep, I already tried that. Thank you for the suggestion.
