FormLoom Problem
Hey there,
when I publish my FormLoom stack used with the “Codex” - Theme, it doesn’t work (it doesn’t publish the stack).
What can I do?
Is it possible to try the same setup with a different theme? If that works then you’ll know it’s probably due to a theme issue rather than something you haven’t done with Formloom and its accompanying stack.
Rob
