Please open a support ticket with issues. I’ll need more information such as the version of Stacks and RW you have installed. You may open a support issue here
Thanks. We are all easily confused at the anticipation of the Steps being removed as an option. The Step feature is a powerful feature for large forms that benefit from being split up into steps, but having a 2 steps on a single page short form is not such a good solution. Great you are looking into it.
FormsPlus 1.2.2 just hit the update server. This version adds an often requested (and nifty) feature for Form Submission Templates. Form Submission Templates can now include a URL to uploaded files. This will allow admins to simply click on the link in their email to download the file. This option can be found in the Form Submission template settings
Yes, it is finally here. Database support! FormsPlus can now save your form submissions to a MySQL (or MySQL compatible, e.g., MariaDB) database! Of course, I couldn’t just add MySQL support. FormsPlus will automatically do the following for you:
Set up your MySQL table
Set up your MySQL columns for you in the appropriate type (varchar, int, etc.) and size or length
Automatically perform database migrations for you. This means that you don’t have to worry when you change your forms!
Automatically log visitor info such as IP address, User Agent, and Referrer.
All you have to do is give FormsPlus some basic database information such as hostname, username and password and it’ll do the rest. You can even use the same database credentials for all of your Forms. FormsPlus will save a unique form id with every submission so you can group submissions together by type. Now, how’s that for plus
Check for updates and enjoy!
-Greg
FormsPlus v1.3.0
New Features
MySQL Database Support
Automatic database migration (no need to change the columns in your database)
Save user info such as IP, Browser, UniqueID, and Referrer
Save file upload name
Consolidate forms into a single MySQL database (but still know which form it originated from)
Bug fixes
Fix an issue where the FROM field may not be set for email receipts
This stack looks interesting, though I would like to see a demo.
The link for the demo on the Chilling website is incorrect (as is the link in this thread to the stack). Have tried using the same structure as other demos of products, though can not find it.
