Rudy
                    26 September 2021 18:42
                  1
              Hi, using F6 and I have a problem with the Forms.  When I select a ‘Select Box’ or a Multi-Select, there are no options select possibiltys, and the inspector shows no check at the 'Hide Select Options?  What am i doing wrong?  Can anyone help me please?
Thanks,
Rudy Lambechts
                teefers
                    26 September 2021 19:20
                  2
              Hi Rudy,
Not sure what you are asking here. If you want to know how to add an option, there is a blue +  at the bottom of the Select box, and MultiSelect form stacks. Just select that an pick Select Option.
Again, Sorry but I don’t know what you are asking here?  Not sure what the “Hide Select Options?” is you are looking for?
Have you had a look here:Forms | Foundation 6 Stacks for RapidWeaver (foundationstacks.com)
You can also download the some free templates to help you get started along with the project file Joe used to create the demo site here:
                Rudy
                    26 September 2021 19:52
                  3
I don’t find this select option (is’nt showing in my screen.
This is what I see by choosing Select Box or Multiselect
                teefers
                    26 September 2021 20:09
                  4
              Can’t really see what you are seeing in the screenshot.  Looks like you may have added a  text box inside the select box.
Here’s what I see
Add a from to the page:
Add a Select box to the form:
Select the blue +  on the select box:
Choose Select Option and it adds a Select option stack to the select box:
Your screenshot I can’t see the end of the form (Form Actions) or the Blue add buttons.
                Rudy
                    26 September 2021 21:16
                  5
              Thanks, indeed …. It’s working well now!
Rudy
                joeworkman
                  6
              Curious. What was it that was causing the issue?
                Rudy
                    26 September 2021 21:51
                  7
              Hi, my mistake. Apparently, I put text field in the wrong place. Doug Bennet has helped me in the meantime.
Thank you !
Rudy from Belgium.
                system
                    27 October 2021 07:52
                  8
