I’m trying to use rapidweaver+foundation+armadillo.
I need to customize the posts title style. I tried to set “Custom CSS” into the global settings with code like this.
#blog-permalink a {
background-color: yellow;
color: red;
font-style: italic;
font-size: 10;
#blog-entry-title a {
color: red;
font-style: italic;
font-size: 10;
Nothing change.
Any suggestions will be appreciated.
Thanks in advance
Pietro
RapidBase
(Matthias Wolf)
5 December 2016 11:52
2
Did you already try to place “!important” before the “;” sign in each line?
So that a line would look like this: color: red !important;
Mathew
(Mathew Mitchell)
5 December 2016 12:11
3
@pietrob71 It seems like you are inserting this code in RapidWeaver. I believe it only works if you insert into Armadillo directly. Login to Armadillo, go to Settings tab. Choose General Settings, then add to the Custom Styles area.
RapidBase:
important
Also using “color: red !important;” it doesn’t work
I inserted the code using the armadillo’s administrator web inferface and I wrote the code in its custom css area.
Mathew
(Mathew Mitchell)
5 December 2016 22:43
6
Okay, the code you used was a bit off. Try this:
.blog-permalink a {
color: red;
font-style: italic;
font-size: 10;
.blog-entry-title a {
color: red;
font-style: italic;
font-size: 10;
I don’t know what you are trying to do with the permalink code. But the entry title works just fine (I just tested).
I hope this helps a bit.
nimblehost
(Jonathan Head)
6 December 2016 02:09
7
@pietrob71To target Armadillo content specifically, prefix your CSS with “.armadilloContent”, like so:
.armadilloContent .blog-permalink a { ... }
Using .armadilloContent prefix works like a charm.
Thanks a lot
