psmiles
(Peter Schmitz)
11 September 2018 09:57
1
I want to build a website using Foundry, and I want to use Formloom 3 to make a contact form. All in RW8.
When I publish the site, in the part where the contactform should appear only the first lines of the header are shown.
Some suggestions to solve this problem? Thx in advance.
NeilUK
(Neil)
11 September 2018 10:02
2
In the Formloom settings, try selecting “No Theme” at the bottom of the inspector. Also make sure sure you have “SSL Mode” selected if your site has an SSL certificate (https).
psmiles
(Peter Schmitz)
11 September 2018 10:22
3
@NeilUK Thx man - problem solved!!
system
(system)
Closed
11 October 2018 20:23
4
