I’m afraid I can’t answer your question but I’m puzzled as to why your post should (apparently) be an image rather than text.
Peter I don’t know about this. It’s no the first time somebody make the comment. I posted as usual. Hope somebody in the board will help us. Thanks anyway.
How did you strip these files?
If you didn’t uninstall each stack from within RapidWeaver, then the plist and other files may be damaged due to improper removal of stacks and plugins associated to RapidWeaver.
I would try downloading the full version of RapidWeaver again as outlined in other posts.
Do you have any firewall/anti-virus/disk cleaning utilities installed?
Brad
Generally 'Disk Cleaning apps" for the Mac are destructive unless you really know what you are doing… I would ditch those to begin with.
There were some issues with the 6.3.8 update from 6.3.x, the resolution was to download and install the full version
Download the full version of RapidWeaver 6.3.8 here
it should unzip into your downloads folder, move it to applications folder, restart. issue still persist?
Brad
Thanks Again Brad.
I will do all you told me and keep you posted.
Muchas Gracias,
Humberto
Sunny Puerto Rico
