I see Google now likes ‘Microdata inserts’ for seo purposes.
How would one go about inserting this with Rapid Weaver??
https://schema.org/docs/gs.html
Any tips would be greatly appreciated!
What are you using to build your sites? If Foundation then you can use Structure and the schema option in the Header, Paragraph and Image stacks etc. Or you can do it with the likes of Big White Duck’s Sections Pro, Header Pro and Paragraph Pro stacks.
Oh thank you soooooo much!!!
I’m using Stacks with Forward theme.
Thank you Stuart!!
