Grid using custom html component 85% complete download
thought I would see if I could control a three grid layout just tailwind and Elements
Lots to do, the cols and rows were fixed for the grid not set a lot up yet
I even have one of the grids scrolling, kind of shows in part how grid works
https://we.tl/t-TwVelw7I73
about 80% complete, poor resolution video, good exercise to practice Elements
you can now have 1 2 or 3 grids
Not added margins, drop zones or text boxes yet
@dan I highlight the override circles for each screen size, at end of the video, is there a way I can hide these
gridplay80
I’m not 100% sure what you’re up to here, but it all looks really cool :metal:
https://we.tl/t-9UUiHG9YK2
you can try here
I just need to hide the override circles next to my controls and leave the Elements controls with the overrides
not sure what settings I left in the custom Element
Still a few typos in this version
borders radius etc are still linked from mobile settings
https://we.tl/t-U1rW8APrAZ
a stripped back version, not finished, using drop zones only
further to Dan’s grid video, ok a few % moved on in my learning stage and my grid Custom HTML Element
Almost decoupled everything from mobile anD desktop, only padding left
This is just grids with 3 grid items, position anywhere and resize, remove grids, drop zones removed for now
CleanShot 2024-09-04 at 20.43.31
I have added 3d views as we’ll
Elements makes this easy
Started to learn Alpine JS now, so time away from this
CleanShot 2024-09-04 at 20.56.19
restarted the backbone now just a copy and paste exercise to have all options working, have a different workflow now, so will be quicker, change from 3 grid items to 5 grid items hopefully
wanted to have a background grid to make it easier + a great learning exercise for me
Elements is really great just trying to learn alpine js but keep wanting to try different things in Elements
see video below
https://we.tl/t-EisWhPGTEG
Nice work Steve!
moved on from video above
added some controls back in, a few more to add, didn’t bother centring etc for this video as file would be too big
can turn off grid element, dropzone and grid layout/background
CleanShot 2024-09-08 at 08.08.39
@dan is there a way of removing the override dots?
CleanShot 2024-09-08 at 15.13.22@2x
about 85% complete works I think, maybe odd bug if I didn’t copy paste replace 100%, checked out of most it
I have left the 5 grid items in both md and mobile showing, grid setups can change both size and grid size,
turn off grid items you do not need in each grid item area
the only thing to be aware drop zones need to be overridden for mobile and md with Elements, easy enough, otherwise they show in the other both screen sizes
by the way the images are mine no copyright issues
there is a mt-12 in the html
To turn off the responsive override, set the responsive property to false in your component configuration!
Dan thanks just realised it was in the manual, I had seen it but forgot
