Do you have an how-to documentation you can share?
Just wanted to let everyone know we are aware of the issues. Looks like for users of Live Data you will only need to change a share setting once our stack is updated here shortly.
I’m glad to have come across this thread! Explains a lot due to the issues I’m currently experiencing! Staying tuned for updates! Both very heavily used stacks and incredibly useful stacks!
Thankyou to both for looking into the fixes needed!!
Expect an update to Formsnap today to fix this issue. No ETA on Formllom just yet.
Here is a build of Formloom that should fix the issue.
As always, make backups, then test it out.
https://yabdab.s3.us-east-1.amazonaws.com/beta/FormLoom.rapidweaverplugin.4.0.14_b538.zip
This works, but only if the columns are ordered in the same way your form is setup.
I am looking to see if there is a way to map to specific columns as it did before
First I’d like to thank Mike and Johnathan for working on these fixes.
Formloom 4:
CAN ANYONE ELSE CONFIRM-data posted to Google Sheet, the issue is the data posts in the order the form is built-it DOES NOT post data matching the header of the Google sheet.
I have a complex form that I will be testing later today as soon as I have time. I’ll report back with findings.
New build that should fix the mapping of values to correct columns …
https://yabdab.s3.us-east-1.amazonaws.com/beta/FormLoom.rapidweaverplugin.4.0.14_b539.zip
Perfect! Thank you Mike!
Just tested and works like a charm!
Any progress on Formsnap?
For those using the Live Data Stack, we have just released an update that switches to the new API. You can get it by checking for updates in the Stacks library panel. There is a slight change to setup that is detailed when enabling the “Show Setup Tutorial” option in the settings panel. If you run into any issues or need help feel free to contact us here: 1LD RapidWeaver & Stacks Support
Thanks Jon - update installed, small change of settings (name of sheet) - all working fine again!
Great job.
Thanks Jon. Sheet sharing setting changed, and all working fine now
Confirmed. All sites using FormLoom and Live Data back again and running.
Phew, that’s awesome news. Great to see everyone back-up and running
Keep on weaving!
@georgep update should be available later this morning (EST)
Updates for Formsnap 3.0.7 and Formloom 4.0.14 pushed out the door.
hi Ok works fine, thanks for all.
