New Imac macOS Big Sur verstion 1.1
Mac Air on high Sierra latest updates
old iMac 2011 same as MacAir just for general use in house
Below installed on new iMac and MacAir
Rapidweaver 8.7, Stacks 4.1.3, Foundation 6
all down loaded over the last week and a bit.
The foundation videos on Rapid weaver site which are very good have followed like many others on uTube and Weaver Space. not using the up to date versions of foundation
I have over the last few days had Rapid Weaver frezz with not responding and had to force quit.
If I use foundation 1.8.1 and create a site it works in that I can see a preview from edit mode as should be on Video
but this gives a miss mach sysnc error with Top Bar menu but will not add other pages to memu.
when I disable 1.8.1 or select Foundation 6 or 6 R-to-L can not see anything in preview mode. using the Foundation menus and the Top Bar one.
I did install stackes4stacks with FreeStyle before and I have disabled that still same issue
I also Removed Rapid Weaver from the iMac and re down loaded from app store but it came back with all stacks and Foundation.
same problem with laptop MacAir which i am leaving till I get the iMac working first.
Any help would be great so I can get playing with it as watched all the videos and read all I can find
