@Printery – Hi, Humberto,
For some mysterious reason, in the past, your posts were ALWAYS showing as images instead of text. Here is what I am seeing as your post this time:
How do you do that?
From the source, it does appear to be a jpeg dropped in there!
Just write what I want in MS Word, corrected, pasted in. I don’t know why
this happens.
Just as last time, I thought you were blocking my post. That’s why I stop
writing,
until today. I have no explanation for this. Help me find the mistery.
Please share some light to me.
Sincerely,
Humberto
Mark is not, it cut & paste from MS Word. Don’t know why he black line.
hh
Mark is not, is cut & paste from MS Word. Don’t know why the black line.
I’d steer clear of Word, if I were you. M$ is never our friend
If you using word (or other formatted text app) just use Paste and Match Style Opt-Shift-Cmd-V and you should be ok.
Thank you guys for the help.
From now on I will use CleanText before posting.
– printery
Just a suggestion… If you must use a separate app for composing your posts, why don’t you use Apple TextEdit which is a part of standard installation on every Mac?
Gracias Rob, just resolved the problem. Thanks for the advice.
printery
