Dear all, is there a stack or theme so you can organize a horizontal navigation bar.
Personally I think, the header should be small, not as big as the free examples e.g. Mountains…free in RW Classic. I know easy to organise with Foundry, but there should be more possibilities…Thx very much, Jos
Hey @joskenuk,
Multiple, in fact.
Depending on your wishes, you could take a look if SuperMenu ($15, Stacks4Stacks.com), Mega Menu ($15, One Little Designer) or Clean Menu ($20, One Little Designer) are a fit for you.
If you’re a Foundry or Foundation user, multiple navigation options come with those frameworks including horizontal ones.
Erwin
thank you Erwin! Super…think I will go to Foundry!
