How do you import a web site originally created in Dreamweaver
The short answer: the hard way.
There is no “import” feature into RW. (I so wish there was)
You’ll have to re-create the site from scratch, using the building blocks that RW provides, then copy in the text, etc., as needed.
Alternatively, you could build just the common elements using available stacks (such as the header, menu, footer, sidebar, etc.), then copy/paste the HTML of the content into an HTML block.
However, you are better off re-creating it “the RW way.”
Wow straight into a brick wall. Thanks for your advice it looks like I will have to start again
Many of us have been there and still visit that same starting point - you are not alone.
