how would I write the code for an email address. The HTML code that I have does not put the email into the “To” box of the email so it actually goes nowhere. I see that I need to add “?Subject=” but I’m not sure the whole line. This is how I wrote it:
Ok, it’s not letting me wrote the code to show up.
First part of line is smaller than bracket < then I add “a href=” then in quotes I add mailto: end with a quote " then I add a greater than > then I add the email. After the actual email I type a smaller than < and a back slash / the letter “a” then a greater than >
and it doesn’t work. Could you please tell me the whole line I need to write to add an email that will actually be sent out?
Thank you;
-corey-
Yes, Steve, I have it. That’s how I learned my coding was wrong for the emails. I had a friend check the website and he told me my emails weren’t working as they were coded wrong. I was using coding from WordPress. Now I’m using RapidWeaver and the coding is a little different. I think WordPress is using older coding. But I did purchase and am using the Obscure Mail. Thank you so much for the advice. -corey-
PS: Christopher, how were you able to write coding and have it show on this forum? I tried to write my coding and it would disappear when I posted it. That’s why my note is all jumbled I didn’t know how else to explain what I was writing.
