While re-doing my family portal, I ran into an unexpected problem with PlusKit. In the old portal, PlusKit worked as expected, but now it just doesn’t import anymore.
I am aware of warnings against the use of PlusKit. That’s why I have limited its functionality to @import. It used to work fine, but now it doesn’t, for whatever the reason may be.
So, I would like to avoid using PlusKit altogether. But how to make a Site Map, for example, without using a plugin and the @import function? I’m sure there must be a method I am not aware of, because I’ve never needed it…
Perhaps @isaiah could add a comment? BTW, my version of PlusKit is 4.0.2. RW 7.4.0. Stacks 3.5.4.
